What is this? Starter Solenoid?
lmsmith
I pulled this off the transom. What is it? I'm as green as a guy can get working on outboards. I haven't got a manual yet, waiting for the title to go through before I sink to much money in it.
bitterboater
Re: What is this?
Re: What is this?
That was probably the servo for the hydraulic trim\tilt system.
lmsmith
Re: What is this?
Re: What is this?
Everything was running to it as if the boat was using it, but there isn't any tilt/trim on the boat/engine.
Here's a close up of the cover.
Fireman431
Re: What is this?
Re: What is this?
Did you cut all of the wires or did you find it that way? It looks to me like an older style starter solenoid/relay.
Silvertip
Honorary Supreme Mariner
Re: What is this?
Re: What is this?
That's the starter solenoid. It would have been a little help to know what motor is on this boat. Some older engines had the solenoid inside the boat rather than under the ending cowl.
lmsmith
Re: What is this?
Re: What is this?
Did you cut all of the wires or did you find it that way? It looks to me like an older style starter relay.
Yeah, I cut them off.
It's a 1956 30 hp Evinrude and it does have electric start. I didn't know to tell ya'll the motor. I'm learning as I go.
Is there a way to check if tis one is still good? Should I even worry about it? This one seems pretty rough. Does the new one have to be the same type of one, or do they have a modern equivelant?
By the way guys, thanks for replying.
Fireman431
Re: What is this?
Re: What is this?
Why in the world did you cut the wires instead of just disconnecting them? Or are you rewiring the entire boat aas well?
joed
Re: What is this?
Re: What is this?
I saw one very similar to that once. It was the starter solenoid for a Johnson circa 1960.
Perhaps it is left over from a previous motor.
lmsmith
Re: What is this?
Re: What is this?
All of the wiring is shot, cracking out the wazoo. Yep, plan to re-wire the whole thing. Doesn't appear to be more than ten wires run throughtout this thing.
Here are pictures in the Restoration forum.:
http://forums.iboats.com/showthread.php?t=508004
From what everyone is saying it appears to be the starter solenoid. Motor is a 1956 30hp Evinrude.
Do you have to replace it with the same type part or is there a newer version now a days? I don't think the one I took off is worthy of being put back in.
Silvertip
Re: What is this?
Re: What is this?
Starter solenoids are pretty universal. If it has two large and two small terminals it will work.
