what is this part???
PmDavis300
anyone? its off a late 70's 35hp evinrude. i dont have a model number yet
tashasdaddy
Re: what is this part???
black wire is a grounding bracket. tan is usually a heat sensor.
PmDavis300
what are the little cylinder things for though?
PmDavis300
looks like its a 1958 35hp Lark
35514
does that help?
ezeke
Probably a mercury switch; does it feel like there is heavy liquid inside when you shake it?
PmDavis300
i dont know, its a motor i may be fixing for someone. dont have the part with me, just pictures
tootallofwa
F_R identified it in this thread... http://forums.iboats.com/showthread.php?t=382482
All that stuff you said you did--and nowhere did you say you even looked at the ignition system, which is one of the FIRST things I would have looked at. A 1959 has bad (cracked) coils, unless somebody has already replaced them. In any case, you are wasting your time till you verify their conditon. Also in there are the breaker points and condensers. If the points are worn or greasy, it isn't going to run right.
The wires go to a pair of mercury switches. That is mercury--as in the metal, not Mercury as in outboard brand names. One of them prevents starting the motor when the throttle is advanced too far. The other one prevents the vacuum cut-out switch from operating at other than slow throttle settings. You will find that the wires cannot be re-soldered to the posts because the posts are stainless steel. The wires originally were welded on.
PmDavis300
your right, thats what it is. thanks guys. now i just have to figure out how its wired when i get the motor....
PmDavis300
any one have a wiring diagram for this part? i cant figure out where 2 of the wires go
