There is a constant buzz from the alarm when I turn the key and I noticed when I squeeze the bulb on the fuel line gas starts running out of this tiny hole on this part... What is this part called?
Thank you! What would cause it to leak out of the vent on the vacuum switch when the primer bulb is squeezed and is that what is likely causing the alarm to make a constant sound?
