What is this part called?
Rbrooks2394
There is a constant buzz from the alarm when I turn the key and I noticed when I squeeze the bulb on the fuel line gas starts running out of this tiny hole on this part... What is this part called?
175se
That's the vacumn switch, trips the warning if there is a fuel restriction.
Rbrooks2394
Thank you! What would cause it to leak out of the vent on the vacuum switch when the primer bulb is squeezed and is that what is likely causing the alarm to make a constant sound?
