What is this motor?
bigcathunter
I recently acquired an old Sears outboard Model # is 571.58041 Ser#401-20.969( I think, this is a number off of the block). It is one cylinder water cooled. what is the correct fuel mix and spark plug gap for this? Thanks for any info you can provide.
F_R
Re: What is this motor?
Spark plug is J12J gapped at .050" Yes, that's a mighty wide gap. If the magneto is too weak to fire it, you may have to close the gap down some.
I have one of those motors, runs great. My plug is gapped at .030". Water pump is a real treat if you have to get into it. If it pumps good at slow idle, leave it alone.
bigcathunter
The water pump seams to pump water fine. I have gotten it started but I don't have the bugs worked out of it yet, I completely tore apart the carb for cleaning and don't have the mixtures quite right yet but it has been a blast to work on because of the simplicity of everything on the motor. I can't say as I will ever really use it but it is pretty cool to have something this old that still works.
