What is this black plastic material on the center console?
John90290
I'd like to rebuild my center dash like the one in the picture attached. what is and where can i find that black plastic material they use? I've seen it used on the boat repair show but don't remember the name?
Thanks for the help.:):)
erikgreen
Re: What is this black plastic material on the center console?
I can't exactly tell from the angle you posted, but it might be a synthetic cutting board like material.. I forget the trade name. Sea board?
Main reason I post this though, is to suggest that you replace the black stuff with a piece of aluminum sheet... it's a bit harder to work, but it would look really sharp :)
Erik
Windykid
You could just use a piece of lexan or plexiglass and paint the back side black.
dingbat
Great, thanks, that's it!
Found some here....
http://www.bluewatershipsstore.com/Cockpit/Seaboard.aspx
I aggree that aluminum would look better but worried about oxidation in the salt water enviroment? i will check out both options.
Thanks again!
I used King Starboard when I did my installation. Not sure if Seaboard is the same stuff or not.
The last thing I would use is an aluminum panel on a SW boat. Aluminum oxides and pits rather easily in that enviroment. It's hard enough trying to keep my hardtop looking decent let alone a control panel
