What Happened to The Fluid in my Compass?
ShaneCarroll
I don't know how or why, but all the fluid (water?) in my compass evaporated!:confused: It was in there before I left to work in Ohio, I covered the boat, and I come back and it's gone. .:confused: Does this mean I have to buy a whole new compass or can this one be refilled?
JB
Re: What Happened to The Fluid in my Compass?
Depends on how the fluid (odorless mineral spirits) got out.
If your compass is a Ritchie, you can purchase a new ball and card, but it would cost almost as much as a replacement compass.
If a Ritchie, go to a drug store and ask for odorless mineral spirits. You can now pull and refill the ball. On some models you will need a syringe and needle to penetrate the rubber seal; on others the seal is removable.
If it is not a Ritchie, trash it and get a Ritchie.
Boatist
My compass was good for about the first 15 years but now have to top off about every two years or I get a air bubble at the top.
If your fluid was good one day and gone the next then likely have some type of seal failure. Unless it a 6 inch card or larger probable cheaper to get a new compass of your choice.
As far as the compass fluid itself West Marine Sell Ritchie compass Fluid
SH-0154 in one pint bottle. I do not remember how much it was but was cheap.
It is possible the fill plug came out. Mine has a Fill cap then under the fill cap is another screw to remove so you can add fluid a drop or two at a time.
Good Luck
Silvertip
Honorary Supreme Mariner
Check for a wet spot/stain on the floor. That's where the fluid went.
ShaneCarroll
Well, it was three weeks that the fluid had to drain out, so any wet spot would have evaporated. It is a Ritchie compass, I will check it out, but probably end up getting a new one. I just wanted to know if it's common for the fluid to disappear, or if maybe it's broken. Thank you all for the advice.
