what glue will reattach my interior?
KCKracker
i have a 74, with ribbed vinyl glued to the gunwales, but its falling off, i tried 3m spray adhesive and it doesn't work. what will really glue this stuff back on before i get mad and rip it all out?
ajgraz
Exactly which 3M spray adhesive did you use? Did you let it "tack up" a little before joining the surfaces?
Is the back of the vinyl smooth, woven, "fuzzy," or ?
What surface are you adhering to: bare fiberglass, painted fiberglass, some sort of wood, pressboard panel, or ?
KCKracker
i sprayed both sides and waited for tack up per directions, first hot day it falls off. its smooth and attaching to fiberglass.
ajgraz
But which 3M spray did you try? There's like half a dozen different ones.
Woodonglass
Honorary Supreme Mariner
Uhmm Weldwood "Solvent Based" NOT the Water Base. Contact Cement. It WON"T come off again.
sheboyganjohn
Used the weldwood spray on the hydro turf on my jet ski that was falling off, worked well.
