what do you replace the drain holed with up on top when you replce the transom?
hotrod53
The drain hole tubes look to be crimped thru the transom aluminum and wood, I used a die grinder to remove them. What do you replace them with?
Re: what do you replace the drain holed with up on top when you replce the transom?
Sea-Dog makes the replacement drains that I used and moeller makes the flanging tool used to install them. Drains are cheap, tool is a bit spendy.
hotrod53
Found some new brass spashwell drains, cut them to size, flared them with the ball end of a ball pene hammer and then tapped them down...done!
