What are these things
gonefishie
I was waiting for traffic to clear at a gas station so I can pull out then this trailer pulled in. What are the bars attached to the hitch and trailer's tounge by chains?
wellsc1
Re: What are these things
My guess is anti-sway contraption.
Bass Tracker TX17
Weight-distributing trailer hitch
Weight-distributing trailer hitches are used with a receiver hitch and special parts that distribute the tongue weight among all tow vehicle and trailer axles.
steddy
That is known as "Weight Distribution." Basically, it works like the handles on a wheelbarrel. The chains pick up on the ends of the bars that are attached to the hitch. The hitch then torques around, forcing the load of the tongue farther forward on the tow vehicle.
This particular system is also sporting the sway control. It is just barely visible on the passenger side. It is essentially a "friction brake" that works between the side of the tongue of the trailer and the hitch. When the trailer "fishtails," (sways), the sway control basically provides resistance so it can't fishtail as much. A properly set up weight distribution hitch can help a little bit with sway, but not as much as a proper sway control.
These hitches are pretty near and dear to me, and I don't have to pretend to know a lot (but not everything, of course) of what there is to know about them. This particular system appears to be Reese brand, notable by the drawbar shape, pitch control, and flares at the end of the bars by the chains. Advantage of flairs: easier upgrade to a dual-cam setup, which combines with some other parts to become an anti-sway setup. The system he is using retails for around $450, assuming it is a Reese setup.
It looks like the snap brackets on the tongue are a little far forward, assuming the trailer and truck are in a straight line. When the truck and trailer are aligned straight, the chains should be vertical, and the tails of the bars should be about 1/2 way (general guideline I use) between the ground and the bottom of the frame. The trailer itself should run level or just slightly downhill in the front. Just a few inches up or down can greatly affect the handling of the trailer no matter what hitch type is being used.
steddy
p.s. - his safety chains are riding pretty low there. He should probably disconnect them, twist them around a couple times, then hook them back up. Looks like they might drag a little.
arks
They're not recommended for use with surge brakes because they throw off the surge sensor, causing the brakes to be less effective.
From personal experience experimenting with this setup, the trailer brakes will still work but not be nearly as forceful when slowing, which could be a BIG problem in an emergency!
steddy
Yep.
kenmyfam
Still got a set in my garage from our house trailer days. Work very well when set up correctly.
gstanton
We use them ALL the time on our travel trailer. The TT has eclectric brakes and is ~ 8000 lbs.
Never on the boat trailer. It has surge brakes and ~ 5700 lbs.
BTW... Ford F-150 7700 w/ towing.
Agree with everything steddy says.
Jeep Man
My father-in-law had them on his old travel trailer, and he loved them. They helped relieve the tongue weight off the old station wagon. Supposedly, you could remove the cars back tires and it would support the weight, not that you would want to.
Jeep Man
