rickasbury
Ensign
Thread starter- Joined
- Jul 13, 2011
- 914
So, very lucky today ended safely and I'm just not 100% on what happened today.
So, I have a 27 ' rinker on a tandem axle trailer. I have been working on getting the boat back to the water and it has been a struggle. A few weeks back I discovered I had a broken leaf spring. So, thanks to help here got that replaced. Brought the boat home from where I did the repair (5 miles) to the house, mage one trip to the ramp (10 miles) and then back home. Today, went back to the ramp for a test run...started feeling some vibrations, pulled over 2x to look thinking I had lost a tire on the truck or the trailer but could not see anything...just before we got to the ramp I had to pull over again . Freaked out when I saw the tire-the lugs where all ate off, holes in the wheel wallered out. The whell was about 10' from completely coming off. Lucky. So I managed to get the wheel off, called a tow truck who got it back to storage. So I need a new wheel and a new hub.
I'm trying to figure out what I screwed up. I have the hubs that have a rubber piece you pull off to get to a zert that is on the end of the spindle. It was gone and the hub was very hot. Once I got the wheel off, the brake was not locked up (disk). I can see if I did not have the wheel back on right when I snugged the lugs or just did not snug them properly - why would the hub be so hot? Did the hub get hot causing the lugs to come loose somehow? I have new bearings but have been having brake issues...
