Long time has passed, still not having repowered my boat properly, I learned some things:
- carburated technology might be simple and easy to fix, but I just don´t understand enough to make it work for me. I just don´t understand any unpredicted behaviour and I can´t fix it. I am to slow to undertstand any of the complexity of engines, rocker arm ratio, lift, whatever to make reasonable decisions.
- Also any work done in machine shops here is so expensive that it barely makes sense using used parts and having them redone.
- Meanwhile I think I can drop almost any engine in my boat and attach it to the DP290. Looking at the 880 block I can just attach my old small flywheel and my alternator (since the block also has the old screw pattern). Then the old bellhousing can be used. Just the piping and wiring is a bit different.
So I will try to throw in a MPI, because sensors speak a language I understand. I can (sometimes) make sense of their reading to troubleshoot.
Just wanted to keep you updated here, since there will most likely not be any progress on this original project.
