drewpster
- Oct 17, 2006
- 2,059
I need some suggestions here. I need to figure out where I am going to put everything in the stern of my tri-hull.
I am considering the possibilty of closing the area under the splashwell. Originally the fuel tank was mounted on the port side and a single start battery was mounted on the starboard under the splashwell. I am adding a second battery for a transom mount trolling motor. Ideally I would mount a new tank in the center and the batteries to each side of the tank. The problem with that is if I mount the tank in the middle it blocks access to the deck drain. I also considered elevating the tank 4 or 6 inches to allow access tot he drain. But that will still make the drain a pain to get to. You think I should just scrap that idea and go back factory with it?
