weak starter
MCM
Re: weak starter
From the battery to the solenoid and engine block should be 4 gauge battery cable, from the solenoid to the starter 6 gauge should work
Solittle
Re: weak starter
I doubt that wd 40 solved your problem. It may have delayed it some. You still need the right wire & clean connections.
gulfcoastfisher1
Re: weak starter
well it runs fine so i am not going to try to fix it when it already fixed thank for the post though
