countryhick
Thread starter- Joined
- Feb 29, 2012
- 12
I recently acquired a 2005 Bayliner 185 with a Mercruiser 3.0. The boat seems to be in really good shape and has always been stored indoors. The only problem I have found so far is a spot above the fuel tank that flexes a little when I step on it. This is right where you step off of the engine cover and I'm sure has been stepped down on pretty hard many, many times. It sounds pretty solid knocking on it and only flexes a little when I step down on it. I'm thinking maybe there just isn't quite enough bracing in this area above the fuel tank. Maybe I'm just worrying too much. Has anybody else noticed this in this spot? Is there anything I could/should do short up ripping up the flooring?
