Weak Hand holds?
wgoodhoofd
Has anyone else noticed something weak about the Four Winns hand holds? We had our 180 Horizon on the water for only 4 hours before the handle in the left bow has come undone! We'd tighten it, but the entire backing plate has come loose. Any suggestions?
unlimited171
Re: Weak Hand holds?
If it is one of the new 180's I would contact your local Dealer and see if they can do a warranty on it, Four Winns is pretty good about resolving customers issues, and there backing plates usually hold since they use a bolt and nut with a plate instead of a screw into wood as some manufactures still do .. they will probably apply locktite to the metal/nylon nut
