Weak Decking
jkb1694
I have 1986 Baja Sunsport the fiberglass decking has some weak spots down the middle. My first question is how do I go about repairing this? My second question is do you think it is just deck rot, foam rot or one or the other or both. I understand we will not know for sure until we have cut into the decking but was just wondering if anyone else has had this problem. If it is both how do you replace the foam in it as well?
Woodonglass
Re: Weak Decking
Welcome to iBoats!
Hard to tell what is going on. You WILL need to cut out a section of the floor to know for sure what is going on. More than likely it is BOTH. There are PLENTY of examples here on the forum that will SHOW your and explain all that will be necessary for you to make this repair. Start by looking at the links at the bottom of the page.
