Watering bilge
Chief9
Question from a new boat owner. I have had my new Monterey 204fs with a Mercruiser 4.3mpi out twice. After returning home and taking the plug out about a third to a half gallon of water drained from the bilge both times. Is this normal? I didn't take any water into the boat, nor did I get anywhere near that much in the boat when cleaning it. Thanks in advance.
Grub54891
Re: Watering bilge
Time to have someone else drive and get in there- carefully- and look hard for any leaks. Before launching,check any through hulls and such for looseness and bellows to. Do you have a water systym? Them leak at times also when something is amiss.air conditioning? Anythigs possible!
Grub
Chief9
Re: Watering bilge
No water system. Thanks for the input Grub.
Mi duckdown
Re: Watering bilge
I/o correct? Run the motor on muffs, No water? then dunk boat in lake and see if there is a leak.???
Thalasso
Re: Watering bilge
Is this a new boat or new to you? If it's new to you i would be looking at the bellows
H20Rat
Re: Watering bilge
So to things to check... while on the water, start the engine up and watch for leaks around the engine. If that is dry, then turn the engine off and tilt up the drive and watch.
tazrig
Re: Watering bilge
Do you trailer the boat? Do you keep it covered when not in the water? When you store it is it with the bow way up and the stern down to allow for full drainage? Sometimes a little rain or wash water can hide in the bow and not show up until you splash it and the stern goes down. 1/2 to a 1/3 of a gallon really isn't that much water although ideally you don't want any. I'd check the things mentioned above to make sure it's not a mechanical issue that could get worse but at least, at the moment, it doesn't sound too serious. If all mentioned in the above posts checks out than just Monitor it though to make sure it doesn't get any worse.
tpenfield
Re: Watering bilge
+ 1 to what Tazrig said . . .
The water may be getting in the forward section from washing, etc. and then works its way aft when you use the boat.
Still, I would check the engine compartment for leaks, both with the engine running on the muffs and in the water just to be sure. Use a mechanics mirror to see places where your eyes can't reach. Be safe looking in the engine compartment while the engine is running . . .
Chief9
Re: Watering bilge
Thanks or the replys. The boat is new, has less than 5 hours. It is trailered, with a bow and cockpit cover and kept under a carport when not in use. I will certainly follow through with the suggestions. It's going back to the dealer this week for some minor warranty fixes and I will mention it to them as well. Thanks again!
