Water is traveling up the drive shaft and rolling over and out toward the front and down the mid section, under the power head. I had a guy check this out over the weekend, who is on a contract list for a local Coast Guard Station, and it was all new to him too. Just heard back this morning and after a call to Florida he got this: This particular motor is prone to water problems. Not lots of water but all the same they are leakey. My guess is the pump design itself. You can almost see inside the top of the housing and that grommet we talked about at the top doesn't make any contact with the drive shaft, it sits outside on a shoulder in the mount. That's why I tried an extra o ring on top of the impeller. Can't put an o ring at top of the mount because it won't make contact with anything to keep it pressed into place. Also to answer your question about the drain holes, the holes in this lower unit are about 1/8 round and forward and do in time drain most of the water out. I've put two OEM water pump kits in, 5001594, and deciphered information between 20" 25" and 30" shaft's and something other than a 60' V4. Thinking next year maybe something after market. For curiousity's sake the Stern Drive is P/N 90-305-60-20-95-06, small gear case with curved fins. Should be a Ficht motor. I should include that this motor has been a work horse. This was my Father in Laws boat and it's got 18 years of service and only had lower unit rebuilt once and highly maintained.
Had this running a good ten minutes or so Monday. No alarms and new t stats. I'm going to put it in the water over this weekend coming up, I believe all will be well.
