Mariner 25hp long shaft 1996 2 stroke tiller. This model is the same as the '96 Mercury of the same specification.
When I run this, the water stream is very intermittent. I'll run it, and it will just barely sputter any water out of the pee hole. It will open up and fully pee water for about 5-10 seconds, and then stop and sputter for 5-10 seconds, and then go back. Not sure how the impeller could break in a way that behaved like this ,but figured that was the problem.
I always thought that the motor should always be spraying water strongly. But after research, it sounds like the thermostat could potentially be turning off the cooling system when it cools down enough. Am I making a whole big deal over nothing? Is this how this outboard is supposed to behave?
I will probably replace the impeller no matter what, just because I don't know when it was done last. But how do I know that my thermostat is working right without overheating and finding out "the hard way?" I don't really even know what the thermostat does.
Thanks,
Scott
Thanks,
Scott
