Installed this new motor on a friends boat. It doesn’t have electric trim, only the tilt rod thing. We had it set at one notch above the lowest setting and the boat was proposing. Lowered it down one notch (lowest it will go) and now water is spraying over the transom, but no longer porpoising. Water is only splashing over the port side. Water is spraying out and back like it’s supposed to on starboard side Can the hydrofoil cause this? Any tips?
