water pump
barnyard
installing new impeller ect on apha one gen2.
​the rubber block on rear (propeller side) of case. is this installed with step up (upper drive) or down (toward prop) Thanks
barnyard
Same job, another question
Replacing impeller Alpha 1 gen 2. There is a plastic piece (3.5"x2.5") that slides into channel in upper unit. Part has a "x" molded into it and small notches on each side. Does "x" face forward or back and notches up or down? Also requested advise 12:52 pm earlier no responces. Please help
