water pump ?
dodger7847
ok carb cleaned and she runs,But,1978 clinton seaking 1978 air cooled and waterpump below should i have a stream of water from it cause all i have is a mist coming out is this ok or ?? also a slight oil on my finger when i felt it is that a concern ? thanks.
dodger7847
Re: water pump ?
mrcrabs, do you think i should replace waterpump also, get waterpump kit and impeller ? thankyou.
F_R
Honorary Supreme Mariner
Re: water pump ?
Those impellers are super chintzy. The rest is probably ok.
M
mrcrabs
Guest
Re: water pump ?
not unless its pitted bad or the drive shaft bushing is gone or into the housing, but be sure to get a new key or pin
