Water pump snafoo!!
Hoyt79
:mad: '72 50 HP Johnson...was tightening the water pump housing bolts down and one was a little tough on the last few threads and I forced it and 'pop' bolt broke off in the threaded hole. So, now I have to get a new bolt for it and then figure out a way to get the other one out...will probably have to retap it too...never done that...any ideas:rolleyes:
wifisher
Re: Water pump snafoo!!
Here's one. If it is not threading in properly, don't force it.
Get a left-handed drill bit (cobalt or other hardened bit, not high speed steel), and make sure that you center-punch the broken bolt before you start. Use lube and drill straight. Retap with a spiral tap to pull chips out of hole. Blow clean with compressed air and reassemble.
Oh yeah. Don't break the tap!!!
HighTrim
Im assuming that if you now remove the water pump housing there will be no exposed bolt to brab with vice grips or the like?
If it broke off beneath the surface, I second the left hand drill bit mentioned.
Hoyt79
When re-tapping it is going to make the hole bigger...this is the bolt that sandwiches the water pump housing and stainless plate together and then threads into the hole...so, won't I have to make the holes in the pump housing and plate a little bigger since i will have a bigger bolt going in? Would this alter the pumps performance in anyway?
wifisher
It depends how good you are with a drill. Drill the bolt out a couple sizes smaller than the tap drill for the bolt. Then there is a good chance that whats left of the bolt will screw out. You can use an easy-out to turn it out. The tap is only to clean up the threads so this problem does not repeat itself.
If this does not all go as easily as you hope it does, then yes, you would need to enlarge the hole. If there is enough metal surrounding the threads, I would drill it big enough to install a threaded insert and use the same fastener size on the water pump. If there is not enough material to do this, then a helicoil will allow you to tap slightly oversize and maintain the same fastener.
Kens242REGAL
I'd suggest getting a Easy-Out tool. You drill in a small hole in centre and then tap the easy out tool in, you thread out the broken bolt and then put in a new one.
Try that first, most quality tool stores will stock them. or a good bolt store. Don't go to Walamrt and ask if they have one!
Good luck, let us know if you get it!
tx1961whaler
.......And when you break the EZ Out off in the bolt, then bring it to a machine shop to fix because you'll have a heck of a time trying to drill that thing out of there. :redface:
HighTrim
I agree, EZOuts fail more than they work.
Sixmark
Master Chief Petty Officer
Yep, I'll drill it out and pull bolt threads out with a dental pick and a needle nose if I have to before using an EZout
Art Bernard
Banned
Get a helicoil kit for that size bolt. The kit will come with the correct size drill bit, tap, and new thread insert. I did helicoil all the time in the nav and if your careful it's hard to do.
Art
F_R
I hate Eas-outs and think they should be banned from the earth. However, this is the one case where they have value. You broke the screw while putting it in, not while taking it out. Therefor, the broken screw probably is loose in the threads and will back out with ease.....er, make that "easy-out".
1946Zephyr
Yea, I agree. Easy-outs seem to be made out of crappy material and love to snap off. They work best, if a bolt has threads that are not locked, but the head is sheared off.
One nice tip, when you do any lower unit work, it's best to take a tap and chase all the threads with a lot of WD-40 and get them cleaned out. You want to get the screws and bolts to go about 1/4" below the point that they would normally go, when they are doing what they are intended to do. For example, the water pump housing. If those screws will turn easy enough by hand and go 1/4" or more below the hieght of where the top of the waterpump housing is, then you should be safe as far as sinching down the screws without snaping them off. You definately want to follow this rule, if you have bolts that require a specific torque setting, because bad threads or threads packed with corrosion will give you false readings and the bolts won't be seated properly.
rickryder
Since it broke off on install it just may back out using the reverse drill bit...... I have even used a small punch or chisel and spun out broken bolts...... just take your time :)
1946Zephyr
Sometimes, but not always. There's many times I have found it took more to back out a broken bolt in a case like this.
Hoyt79
My manual said to use the gasket maker/sealer on the bolts before I threaded them...wonder if this had anything to do with it, although the other three went in just fine. I will be using a tap I recon to get all the gasket material out of the bolt holes though.
AlTn
did you use BRP Gasket Sealing Compound P/N 508235?.. I ask because I encountered a situation where a l/u had the w/p screws installed with some type of brown permatex that was a bear to get out of the threads with a tap and various solvents
Tim Frank
If you don't have the tap yet, if you have a decent industrial supply place, ask for a plug or bottoming tap.
Either will give better results here than just a taper tap. ;)
archcycle
The BRP is the brown gunk
RogersJetboat454
If you got allot of the sealer at the bottom of the hole (in other words, you slathered too much on the bolt) it could have basically hydro-locked the bolt from reaching its final destination, and you forced the issue. Like others have suggested, try using a left handed drill bit and it may back out. Hopefully the sealer you used will cooperate, and won't make too much resistance that will stop the bolt from spinning.
I've had mixed results with easy-outs. You can try using one, you need to have patience while using it. Most of the time when I've used them, if the bolts really locked into place, the easy-out will become overwhelmed and just open up the hole you drilled in the broken bolt.
Like others have suggested, re-tap the threads when your done. You need a tap for a blind hole which will get the threads all the way at the bottom. I would suggest using some white lithium grease on the tap flutes to both lubricate the tap and collect any metal shavings made by cleaning the threads. You want to twist the tap in a couple turns at a time, then back it out. DO NOT force the tap or you will easily break it off. It is hardened steel, so it is brittle.
