water pump replacement
dhughes49
is it ok to just replace the impeller for 24 bucks or should i buy the whole kit for 72 bucks. any suggestions.:confused:
99yam40
Re: water pump replacement
Where are you located?
Here in the states there is not much difference in cost between the two, so it is no big deal to buy the kit.
Look at see if the cup and wear plate are grooved and need to be replaced
dhughes49
im in centeral texas those are the cost i got from an online store
99yam40
Did you check this site or your local dealer?
Have no idea where or what motor you are dealing with unless you post that info
dhughes49
sorry its a 95 yamaha 200txrt . should i go with oem or are knock offs ok. those prices was from an online store oem parts
dhughes49
sorry if i crossed some line with that question im new at this i dont whats ok and whats not
Ldavidgrover
Buy the entire waterpump kit. The woodruff keys are hard to get out on the Yamaha's and you'll want to remove it to access the upper driveshaft seals for inspection
robert graham
Considering your time and effort, the entire kit replacement really makes the most sense....new Stainless Steel cup, gaskets, impeller, bolts, shaft key,etc. Good Luck!:)
