water pump replacement mercury 6hp
dyydjbb
First time boat owner and my Mercury 6hp needs a possible water pump and impeller replaced. Any good directions and or tips?
emoney
Re: water pump replacement mercury 6hp
Just to read all the threads you can find and have at it. Nowhere near as bad as you might think it is.
dyydjbb
ok thanks I have been, just never worked on a boat engine before, any idea what this is, it came with the boat but no one knows where it goes or if it even goes to this engine.2012-08-15_10-29-35_946.jpg
carholme
Your engine s/n from a previous post comes up as:
6 60 2-cyl 1958278 2096170 1966 USA
From here:
http://www.marinshopen.se/Motorer/O...a/Mercury2takt2cyl68hp/tabid/480/Default.aspx
The engine is a model:
1060106 MERCURY 1966 6
Parts Listing:
http://www.crowleymarine.com/mercury-outboard/399.cfm
Here is a link to the condensed version of the Clymer service manual which will help you get started. Down;oad it soonest to your computer as the link is short lived.
http://web.ebscohost.com/serrc/pdf?...b43e-f47af0a3bd31@sessionmgr104&vid=4&hid=104
Gerry
dyydjbb
Thanks Gerry some good info in there!
