Hi guys first post, I've been a lurker for a few years don't know why i haven't signed up because this forum is so valuable. On to my issue. I have a 1980 johnson 25 horse that i picked up that wasnt pumping water that great. I planned on flipping the motor so i added an electric start off a blown up 35 i got really cheap and planned on replacing the weak impeller. I bought a whole kit and replaced the housing, impeller plate all the gaskets and the keyway and of course a new impeller. slightly lubed the impeller cup then rotated the impeller the exact same way the old one was and put it all back together key in place put the copper water tube in the intake up top then slid it in the grommet on the impeller housing. this thing won't pump water! i dropped the lower unit again and took everything apart 3 times looked on the impeller plate and i can see the impeller is spinning on the plate when i run the motor. this thing has me scratching my head?.. I ran the motor in a tank above the water intake, how long typically does it take for a new impeller to pump on these, all others have just pumped right away. I ran the motor for about a minute and shut off because i dint want to over heat. any suggestions would be appreciated.
