Water pump issues
stevetags
Hi guys first post, I've been a lurker for a few years don't know why i haven't signed up because this forum is so valuable. On to my issue. I have a 1980 johnson 25 horse that i picked up that wasnt pumping water that great. I planned on flipping the motor so i added an electric start off a blown up 35 i got really cheap and planned on replacing the weak impeller. I bought a whole kit and replaced the housing, impeller plate all the gaskets and the keyway and of course a new impeller. slightly lubed the impeller cup then rotated the impeller the exact same way the old one was and put it all back together key in place put the copper water tube in the intake up top then slid it in the grommet on the impeller housing. this thing won't pump water! i dropped the lower unit again and took everything apart 3 times looked on the impeller plate and i can see the impeller is spinning on the plate when i run the motor. this thing has me scratching my head?.. I ran the motor in a tank above the water intake, how long typically does it take for a new impeller to pump on these, all others have just pumped right away. I ran the motor for about a minute and shut off because i dint want to over heat. any suggestions would be appreciated.
Bosunsmate
How far above the water intake did you have the water level?
When the boats moving forward it pushes water up to the pump.
At idle the boat sinks and the leg is half submerged in water, the pump needs to be submerged when in a barrel, that means like at least 7 inchs above the anti cav plate.
The pump cant suck water up
Joe Reeves
It should start pumping immediately. The water level must be a few inches above the entire water pump assembly.... that would be approximately 5" or 6" above the joint where the lower unit meets the long exhaust housing..
Any lower, the water pump will usually draw in air.
gm280
Stevetags :welcome: aboard. Nice to have you join us here at iboats...
I've read your comment and wonder, was this pumping water before you changed the entire water pump assembly? Reason I ask is because if there is anything obstructing the water flow through the engine, it will never pump water due to water blockage. So maybe you have something else going on in the engine itself for the water not to come through. Also, make sure the water level is a lot higher then just covering the inlet vent. Sometimes it take a higher water level to get the pump to take water and prime. try those things and get back to us with results... JMHO!
stevetags
guys thank you for the replies, my tank was not over the water intake by much! I really hope this solves the problem?i will give it a try with a trash can tomorrow. and let you know
GM, The motor was pumping water before i took it apart. I don't remember what i used to run it in.
stevetags
you guys are geniuses?.or maybe I'm just a knuckle head! I put the motor in deeper water and it pumped right away. Thank you!
Joe Reeves
you guys are geniuses….or maybe I'm just a knuckle head! I put the motor in deeper water and it pumped right away. Thank you!
And you're welcome. After all, if not for "knuckle heads" like you... what would we do, oh what would we do? Probably turn to drinking! :lol:
