water pump impeller
jhayman
I am putting a new water pump on a 1983 350 260 mercruiser in the lower unit of the sterndrive I dont know which direction the fins go inside the housing of water pump the impellor was so damaged that you couldnt tell Can someone walk me through it I have the repair manual but it doesnt tell you which way the fins should be facing or does it not matter ?
180shabah
Re: water pump impeller
Doesn't really matter - when it spins, they'll flip to the right direction.
Gary H NC
Put a little grease on the blades when you install it ;)
hoot
from the merc manual, the fins should be leaning counterclockwise. put the impeller on the shaft and while pressing down on the pump housing, turn the shaft clockwise.
