water pump change out
joej
What is the trick to dropping the lower unit off my DT75 Suzuki?
CATransplant
Re: water pump change out
Ask your question in the Suzuki section. This is for oddball outboards not discussed in other sections. The Suzuki gurus are in that section.
Whoopbass
I don't know how far you've gotten but a lot of times on larger outboards there is a bolt you have to remove that is hidden under the water intake screen or under the trim tab. You might have to unhook the shift linkage behind the carburetor to get the LU to completely drop. Smaller HP outboards you can drop the LU a couple inches and undo the shift shaft coupler and the LU will drop out completely. Your motor could be either way.
