Guys, I pulled the lower end of my 1993 140 and changed the water pump. Now I can not get it back in. It gets about 1 1/2" from making it and hits on something. I put it in reverse before pulling it out, but as I was pulling the lower unit down it was stuck on something. I am not sure if it did not make the transmission change positions. I assume that reverse is all the way down ,and I am now going to check to see if it is in the correct position. I tried turning the prop to align the splines of the shaft, but it seems to be something else so I am leaning towards the shift rod being the problem. The 93 140hp has a bend in the shift rod and when I pulled it down it was facing forward which I believe to be the correct position. Any suggestions on what might be keeping me from getting it back in place?
