water pump 1993 evinrude
dchunter
Guys, I pulled the lower end of my 1993 140 and changed the water pump. Now I can not get it back in. It gets about 1 1/2" from making it and hits on something. I put it in reverse before pulling it out, but as I was pulling the lower unit down it was stuck on something. I am not sure if it did not make the transmission change positions. I assume that reverse is all the way down ,and I am now going to check to see if it is in the correct position. I tried turning the prop to align the splines of the shaft, but it seems to be something else so I am leaning towards the shift rod being the problem. The 93 140hp has a bend in the shift rod and when I pulled it down it was facing forward which I believe to be the correct position. Any suggestions on what might be keeping me from getting it back in place?
Honorary Supreme Mariner
Gear position simply does not matter on this job.-----You need to make sure that water tube engages properly and use an assistant to rotate the flywheel to line up shaft splines.-----You should be able to assemble it without using the bolts to pull it together.
dchunter
Hi racerone, I finally got it and you were correct. Once we got the spline lined up, and the top of the shift rod to go in the hole and aligned to slip into the slot it was a piece of cake from there. It even pumps water!!
