What should the water pressure be on an outboard at idle and at WOT? It is a 79 Chrysler 70hp.
b.gagnon Master Chief Petty Officer Thread starter Joined Apr 28, 2001 Messages 835 Apr 18, 2006 #1 What should the water pressure be on an outboard at idle and at WOT? It is a 79 Chrysler 70hp.
WillyBWright Fleet Admiral Joined Dec 29, 2003 Messages 8,200 Apr 18, 2006 #2 Re: water pressure 7-14 seems fairly common with volume-type pumps, and higher for pressure-type pumps. I think yours uses a volume pump. Pressure pumps use impellers with shorter stiffer vanes. Volume pump impeller vanes are long and limp in comparison.
roscoe Supreme Mariner Joined Oct 30, 2002 Messages 21,989 Apr 18, 2006 #3 Re: water pressure I get 3-4 at idle, 8-10 at mid rpm, 14 at full throttle.<br />This is with a new impeller.<br />When pressures start dropping, I change the impeller.
b.gagnon Master Chief Petty Officer Thread starter Joined Apr 28, 2001 Messages 835 Apr 18, 2006 #4 Re: water pressure Thanks! My numbers are exactly what roscoe is getting.....
