water on spark plugs
tfret
1984 5.7L Mercruiser. I have no.5 and no.7 plugs with water on them when I pull them right after running the engine on the muffs. I pulled the risers and manifolds in the Spring. I replaced the risers as they were badly rusted. The manifolds looked good and I leak tested them over night with isopropanol and found no leaks. Does this mean I likely have a bad head gasket?
joewithaboat
Re: water on spark plugs
maybe,
next step... compression test and/or a leakdown test?
Are you confident the gaskets sealed well on the manifolds?
A mercruiser mech will be along shortly, they will know best based on most common thing to fail.
tpenfield
Yes, do a leak test of the cylinders. Check the oil for water as well
tfret
Could be the riser gasket gasket I guess, I'll check for tightness. No sign of water in the oil. I just had the valve cover off on that side and didn't see any sign of water there either. A compression test is a good idea.
bruceb58
You replaced with a new riser gasket right? Were the mating surfaces perfectly flat and clean including no paint?
Don S
Look at your manifolds and make sure the gasket surface is in good shape. Normally when the risers go, the manifolds are done too. The manifold itself seldom leaks, it's the gasket surface that fails and causes water in the cylinders.
attachment.php
muc
"Retired" Association of Marine Technicians...
Leakdown test would be better.
