I think many will find this inspiring and you will want to rip your floor out if you have water in your foam.
I've been reading on many forums about the subject of water logged foam in older boats with the open type cell.
The problem was first discovered when the floor felt a little springy after the purchase of the boat. Also with the 1976 200HP Johnson in excellent condition, most likely with a recent powerhead, (125 psi on all) and very strong running, my top speed alone with very little fuel (light) was only 46 MPH GPS with a stainless 14.25 X 23 pitch OMC prop. With 2 people on board and a full tank of fuel (25 gallons) 42 mph GPS.
Although this deep V hull sn't made for speed, I expected at least 48-50mph in it with a light load.
I decided to upgrade the seating to a removable post set up with nice fishing seats. After drilling the holes with the holesaw, a lot of water was noticed in the foam. 100% soaked. You would poke a hole and water would drain to it instantly.
I figured out that I must have at least 400lbs of water logged foam in there from the various accounts of water logged boats I read on here and the size of this boat. So before ripping out the still serviceable floor, I decided to try a few approaches too see the amount of success. Sure I wasnt going to get all the water out but at least try to get some out.
My mechanic Jason found a plug in the bilge area that probably was never removed. Looking the plug it was there for a very long time. We had a 2.5 gallon imp bucket by the drain hole and we measured the water coming out. 15 gallons total for a total weight of 150lbs !
Using a powerful shop vac on pressure mode we easily got another 30lbs of water out within 15 minutes after it had stopped draining by gravity. But be warned it puts tremendous pressure on your floors. They will seperate from the stringers if you aren't careful with pressure. I am sure letting the shop vac on for days it would drain a lot of water out. Not all but probably another 160lbs + with enough time. This boat was a great subject for this technique because there are no compartments the air goes everywhere under the floor.
Now we decided that it wasn't worth it to remove the water by pressure because it will just get wet again...
So the floor were pulled. Just the water in the floor was estimated at around 100lbs. So far we have close to 280lbs of water.
We used an empty garbage bin to weigh the foam, it when it was all out.
The soaked foam weighed in at 450lbs !!
All in all, we have removed 700lbs of water from the boat.
So was it worth it ? it sure was... My guess is the boat weighs around 2000lbs dry. So with fuel we are talking about a reduction of weight in the 25% range...
Can't wait to try it in the water once repaired... I am certain top speed goes up by 6-7 mph and a much much quicker plane time.
