I (after 5 years) am having a problem with my trailer brakes locking when backing up on flat ground. My Cadillac Escalade EXt has the std round 7 pin flat female trailer wiring, as does my Pul-toy aluminium trailer. There are only 5 wires.
I recently pulled my trailer/boat out of winter storage and when disconnecting in the dark with not lights, I failed to disconnect the trailer wiring from the truck and pull the wires (5) out of the male trailer connection fitting.
I rewired using the std GM wiring diagram and wire color code. All lights work correctly.
Pulled home yesterday and when I tried backing up the brakes lock up. The automatic surge slides to the rear and they lock.
Because there is no "override" wire to connect to the back up lights, and there has never been a problem before, I am puzzled.
Anyone have any ideas?
