Water Leak
I was just running my motor with the muffs on and noticed a drip of water about every 5 seconds comming from the top spark plug hole area, what could this be? Head gasket, crack in the head? The motor is 2cly. yam. merc mariner. 675-308832 Thanks for any help in advance
Plainsman
Re: Water Leak
Water jacket cover gasket is leaking. You can remove the plug and add some permatex or windshield sealant around the plug hole. I was given this advise, but choose to replace the gasket. I broke most of the bolts and had to take it to a machine shop to get them out. Next time I use a sealant.
And Welcome to iboats!
Re: Water Leak
Thanks for the tip using sealant, Didn,t know if that would work, sure beats breaking bolts I,ve done that also (what a mess) and thanks for the welcomed d:)
Plainsman
Re: Water Leak
Anytime! You've found the best place on the web for repair. The guys here are great!
