nola mike
Thread starter- Joined
- Apr 22, 2009
- 6,096
Didn't pull my drive last season (alpha 1 gen 1). Took on some water and was concerned that it made it to the drive. Pulled the drive and found a small amount of water in the shift cavity. No rust yet. Everything else was dry. Still have the old style shift seals, is that the most likely culprit (bellows look good) ? Gimbal bearing also wasn't as smooth as it could be, and I noticed some cracking on the water supply hose from the drive. Hoping everything will hold till the off season. Any other potential source of the leak? Off season repairs will be:
1. Water hose
2. Bellows
3. Shift shaft seals
4. Gimbal bearing
5. Impeller
6. Trim senders? Will these be a "while you're in there" repair, or will it still be a pita? These mean very little to me...
Anything else I should replace while I'm in there? Right now shift cable is fine (replaced last year), we'll see if that holds up.
1. Water hose
2. Bellows
4. Gimbal bearing
5. Impeller
