Hitnmiss
Thread starter- Joined
- Oct 16, 2016
- 7
I have a older 1974 888 i just bought this boat and im new to the mercruiser line so with that said. I ran the boat when i first bought it and noticed there was water coming from the freeze plugs .well they were stripped out so i pulled the elbow on the left side and re tapped the hole and cleaned out all the rust i could get out of it.which was alot so after all that put everything back together and ran it some more no issues well i went to put it in the water to put a load on the motor well checked all my fluids and belts and everything and i had water in the oil there was about 1 -2 gallons of water in oil pan i pulled the boat out and first thing came to mind was head gasket so i pulled the heads didnt really look like the gaskets where bad but had water in all cylinders before i put everything back together is there anything i may has misssed or need to look for
