water in oil
Phatbob
hi guys need some help, just traded my car for a 1988 capri bayliner omc 2.3l wnet to start her up after setting for about month and found water in the oil. when i went to start the engine i gott some back fire then she ran for about 30 sec. shut it down and pulled rocker to check for stuck valve and found milky oil. is this engine a lost or can she be repaired. thanks for your help Chris
tpenfield
Re: water in oil
How good was the car that you traded???
Most engine problems can be fixed. It is a matter of cost, etc.
Don S
Re: water in oil
Is the oil level raising on the dipstick? A frozen cracked engine block is common if the engine wasn't drained. Problem is, there are almost no parts for the 2.3L engine. OMC was the only company to use them, and that only lasted a few years. Oh, OMC also went out of business in 98 to make matters worse.
Here is a Mercruiser service bulletin that explains how water can get into engines.
View attachment EN_13.pdf
Larry E
Re: water in oil
Check with www.seaway.com ask for Jody. He carries alot of aftermarket OMC GM parts. Dont tell him Larry sent you because it wont help a bit...:cool:
Better yet Google SeaWay because this is the wrong link...
Phatbob
Re: water in oil
thanks for you help that service bulletin was great. ill be draining all the oil changing filter checking if there is water in the pistons.
