Maybe sombody can put my mind at ease, here is the deal...
Bought a 1998 Aquasport 20' CC w/ 1998 Evinrude 115 Ocean Pro for a really good price. Now I think I am finding out why the price was so "good".
I test ran the boat for 45 minutes. engine runs strong, no pwer problems. (I do have a fuel primer solenoid problem but that is minor and I will fix that) but back to the point. I hooked up a flush hose to the threaded water flow indicator port on the cowling to backflush the motor. I expected to see water coming out only from the lower unit intake ports. What I saw was water coming out of everwhere it could...Specifically the joint between the lower unit and middle section. So Of course I checked the lower unit and found it to be full of milky oil which I know, of course is water. SO... I am going to pull it and inspect it, my question is this... Should I put the brakes on my other improvements (have a tee top install scheduled for Monday. very $$$) or is this most likely a minor problem, being that the lower unit ran OK during the test run? Either way I am ordering a new lower unit seal kit...Any advice on what else I may need to do?
Thanks in Advance
Thanks in Advance
