water in lower unit on 81 mercruiser 260
chris0061
Here's the deal, I had, had my boat to the mechanic to do a lower shift cable replacement. Allot of other things went on during that so to make a long story short I took the boat out and my lower went out. The mechanic broke the skeg backing it into the garage and had a new one welded on so when it went out I thought the welder burned a seal and that is how the water got in. I called the mechanic and he said it wasn't his responsibility on that but he would pressure test it and see were the water got in. I knew he took the entire uppper and lower out in one piece so something kept eating at me and I decided to take the upper off and when I did there were two big o rings there. The mechanic evidently didn't see the old o ring on there and put the new one on and tightened the upper up. With the two o rings smashed together would that allow water to get in the upper drive there for mixing with the lower? As soon as I loosened the six bolts holding the upper on water started coming out and I knew there the problem was. I got it off and the boot had water in it. I'm going to see this mechanic tomorrow and I just want to make sure my thinking is right. Thanks, guys, Chris
HT32BSX115
Re: water in lower unit on 81 mercruiser 260
Howdy,
Is this guy a one man show or is it a reputable shop?
Your taking it apart might have given him a "get out of jail pass"
chris0061
he has a 3 bay gas station and does a lot of work for the marina here in town. I know I need to replace the gimbal bearing since there was water in the boot. what I don't know is could the water have gotten in the lower unit from the double o rings in there not letting the water passage o ring seal.
meesh
No, only way water could enter through there is if the input shaft seal is bad. Did he split the unit and leave the oil passage seal out? Also known as the quad ring.
chris0061
If your talking about the little seal that goes between the upper and lower unit I made sure that was there when I changed the impeller
boatguya1
Are you saying you worked on the drive between the time it last worked and the time the lower unit "went out"?
James
