ONERCBOATER
Thread starter- Joined
- Oct 11, 2010
- 536
1983 15hp j15elctr
well got engine running like a charm, starter, charging, starts 1st pull or second and with a lil choke goes straight to an idle. Unfortunately after about 3hrs run time 30min to 1 hr at a time, if have discovered milky oil in the lower unit. So it looks like it is time to Fog the engine and tear into the lower unit, I haven't done this before, but it appears relatively straight fwd looking at the parts diagrams. I have a manual, it isn't a whole lot of good as it covers too many yrs and models in too little space, I have an idea of what I am doing, I would just be very thankful of any pointers on things that a noob might not expect, or that I can get into trouble with.
essentially the "if you do this you will be sorry" and the "it is easier to do it this way" type things.
I expect that I will be purchasing gaskets, O-rings and seals. Should I expect to be replacing any bushings/bearings?
What I intend to do is remove the prop, pull the lower unit from the exhaust housing, pull the water pump and then drive shaft then remove the two bolts that appear to hold everything in from the rear. I have been warned many a time to be careful to not remove the phillips head screws by accident instead of the drain plugs as they hold shifting stuff in, so i am thinking that I should remove these only after i free everything else I can up. correct?
this is the diagram I am working off of.
http://www.boats.net/parts/search/BRP/JOHNSON/1983/J15ELCTR 1983/GEARCASE/parts.html
I would be very thankful if someone would know which parts I can replace that are likely culprits and save me from having to do a complete disassembly.
Thank you very much for your time and patience again,
sean
