water in lower unit/ 63 johnson
Jambla
I have a 1963 johnson 40 hp electric seahorse. water is getting into the lower unit around the shift rod. there was nothing there sealing it when it was torn apart. what do i need to seal this and prevent water from geting in?
R.Johnson
Re: water in lower unit/ 63 johnson
Besides the brass shift rod bushing, a fiber gasket, and a O-ring.
ezeke
Everything is in the kit except the bushing which you probably can reuse.
