sebas54
- Jun 17, 2007
- 334
Hi, I have a 1980 Aquasport cuddy cabin that has always leaned to one side. This spring I've had enough of it leaning so I cut a hole in the back left corner. I found foam that was moist with water. I removed all that I could till I was at the fiber glass. There was a pool of water under the foam so I sucked it out with a vac. I covered the hole and installed an access hatch. It rained the next day, so I went to check if water accumulated. It did. I am thinking of putting bilge there but I would like to know where the water is coming from. It is out of the water and has been. Could the water be draining from the surrounding foam that is next to it?
Without having the foam, will this now be dangerous? (I don't plan on sinking)
Any advise or suggestions are greatly appreciated.
Thank you.
Thank you.
