Billie Jean
Thread starter- Joined
- Aug 6, 2009
- 2
Hello boat world! I am new to i boats but have been reading several different posts for the last week. I have a 1990 Force 50hp that has water in the bottom cylinder. Prior to changing the head gasket i has 150psi on top and 120 psi on the bottom.I changed the head gasket and have 150 psi on both cylinders.
Did a test run and it seems like it was running worse and more water is in the cylinder.
I am going to replace the exhaust gasket however i did not see any obvious damage when i removed the cover. Also if that gasket was damaged would water be in both cylinders?
Any help or input would be greatly appreciated......
