water in 4 cyls
cbootes
I have a 2002 powerquest 6.2 liter silent choice exhaust after running the boat for half hour the boat sits for 4 hours. Water fills the even side cylinders. After pulling the plugs the engine will run any ideas it only has 175 hours Thanks
95yj
Re: water in 4 cyls
Check your exhaust manifold and riser.
180shabah
Re: water in 4 cyls
Yup, one of them is leaking. Find it, then replace everything, Manifolds and risers / port and starboard.
Are you in fresh or salt water?
sea wolf
Re: water in 4 cyls
Let's ask Don. He's the resident "expert".
wire2
Re: water in 4 cyls
Does the exhaust slope down to the silent choice butterfly?
If you run "quiet", shut the engine off, then open the transom pipes, does water flow out?
Bt Doctur
Re: water in 4 cyls
Did you recently have a overheat? you may have cracked a manifold or riser or both.remove the cooling hoses to the suspected manifold and kink them, turn on water, run engine NO MORE than 2 minutes, let stand 15 minutes, pull plugs.
water in cylinders- head, head gasket, cracked block
no water in cyl.- cracked manifold/riser
