water from pee hole is pretty warm
dreamchaser
Today I started up my new, used, 1994 120 johnson model j120tlerk , she fired up real good ran fine. While keeping a close eye on cylinder head temps and waiting for the tell tale to pour out, it seems to take longer to start than my 1983 115 rude ..but it does ...anyway. the water was getting pretty warm ..almost hot ...thats when i shut it down. I dont think the water should be that warm but dont want to do damage. checked impeller ,all seems well , checked t stats ,, never seen those kind b4 , Im thinkin maybe pull head covers off to clean ? any ideas guys .thks ......Leo
Cricket Too
Re: water from pee hole is pretty warm
What were you monitoring the head temps with and what was the temp of the motor when the tell tale started getting hot? I'm not sure the tell tale runs through the block on that motor, I think it's just a bypass, for an indicator.
If that motor is new to you I would go ahead and just replace the water pump kit, you never know how old it is or what it's been through, no matter how it looks.
dreamchaser
Thks Criket... I was using my digital m meter that has the "wire" temp gauge ...it was approaching 130f but by that time the water was pretty warm from the tell tale ,so i shut it down .it could have been hotter. Also there was no water coming out from the small exhaust ports just below the engine compartment .new t stats i guess .also no alarms where goin off at that point
dreamchaser
Hello all, Changed to a new water pump kit , new t stats . problem solved .....d:)
Solittle
Most of the OMC V4s have an operating temp of around 140 deg.
