frustratedboater
Thread starter- Joined
- Jul 10, 2007
- 506
All,
I have an 85' Mastercraft w/Chevy 350 (replaced the 351), direct drive, with the PCM manifolds. I am experiencing exhaust flow from only the right side manifold. The water is 50-60lbs pressure at the hose, so i know there is plenty of water. During the normal season I had a little flow out the left side, but not as much as the right side, which seems to pour out. I just started it from a 3-4 week sit and I'm not getting anthing out from the left exhaust side.
During the summer, while experiencing the little flow, I split the top of the manifold off to take a peek and it looked fine. No visable signs of rust. I even sprayed water all through it to check if the top piece flowed well and it did. The two side water lines, coming off the thermostat, are pumping out water, so the manifolds are getting water at the source. I pulled out all the petcocks from either side and I am getting water flowing through the bottom half of the manifold! Very strange...
I did notice that the through hull water pickup had a vaccume suction (sucking the cup to the hull) to it--I did not have that before. Is it possible that the block has rust build up at the manifold preventing it from coming through?
Please, any suggestions to my lack of water?
~FB~
~FB~
