jwstandiford
Thread starter- Joined
- Sep 5, 2004
- 14
Hellow all. I have seached and searched for a thread that will help me with my problem and though I have found lots of helpfull information I am still experiencing the same problem.
First off, the motor I have is a 1978, Evinrude 25hp, Model # 25852.
I inherited this motor after my father in law passed and I know that it had been in storage for at least 7 years as they no longer owned a boat. From the first test I noticed this problem and have yet to get it corrected.
The problem: The motor starts and runs great with a good strong stream of water comming from the tel-tail. After 5-10 minutes of running at idle (test running in a barrel) the flow of water gets weak and seems like it will stop flowing completely if let run. As soon as the flow starts to dwindle the head starts to heat up rapidly so I shut it down.
The impeller seemed to be OK but I replaced it anyway. The stainless plate on the bottom of the pump showed some wear but I could not find a replacment. The t-stat was bad so that and the cover gasket were replaced. I blew 100psi air backwards and forwards throught the system while I had it appart and it seemed that the flow was not restricted. I replaced the hose coming from the head to the tel-tail becase it seemed kinked and cleaned out the tel-tail itself. After re-assembling and testing I recived the same results. I then removed the t-stat and tested again with the same results.
Any input would be appreciated.
Thanks,
JS
Thanks,
JS
